1.92: Program aborts when taking screenshots
gonzos-revenge
Post by gonzos-revenge »
I´m using xnview with Vista64. Installed the 1.92 version and tried to make some screenshots from the dektop, for example cpu-z. Everytime when I hit F10 a vista popup comes up and tells me that something is wrong with xnview
and I had to shut it down respectivly vista is shutting down xnview.
When I look into the folder where I save the screens i can see they are all there, so xnview is closed after the screens are taken.
Went back to 1.91.1, thats the only one I found in my backups, and everything went well. No comments from vista, program went down to taskbar when I hit F10 does the screenshot and comes up without any trouble.
Never had this before, exept version 1.92
Re: 1.92: Program aborts when taking screenshots
gonzos-revenge wrote:I´m using xnview with Vista64. Installed the 1.92 version and tried to make some screenshots from the dektop, for example cpu-z. Everytime when I hit F10 a vista popup comes up and tells me that something is wrong with xnview
Really, could you try with the 1.91.6? I have not changed capture feature...
gonzos-revenge
Don´t know why, but the error message is gone. Did a clean install of 1.92 and everything works.
All the times before I only installed the new version above the old and don´t
get any troubles. Maybe thats the point.
Thanks for your quick reply and merry christmas to all
gonzos-revenge
