When selecting this option, it should take this into account for the Overwrite option. For example, the only option that is realistic is Rename or Overwrite. Skip and Ask are both not viable options. Maybe a warning "You have chosen to Ask even though you are using the Original Path as Output. Continue?" Or maybe just gray out all choices except rename and overwrite.
Also, a way to escape out of a batch all at once, instead of hitting Yes/No each time for each item in the batch would also be really nice.
Thanks for the product though, I love using it, hope this helps to maybe make it a little better!
Use Original Path As Output
