GflAx.GflAx.1 (0x80004005) - ASP sample does not run
Aquiladan
Post by Aquiladan »
I'm try to test GFLAx example asp page, that I've found in the package installation, but I obtain this error message:
HTTP 500.100 - Errore interno del server - errore ASP
Internet Information Services
Informazioni tecniche (per il personale del supporto tecnico)
Tipo di errore:
Error to open file
/mytest/GflSDK/GflAx/Examples/ASP/example1.asp, line 12
Tipo di browser:
Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.0)
Pagina:
GET /mytest/GflSDK/GflAx/Examples/ASP/example1.asp
What I've wronged?
Maybe something in the installation or have to configure something?
I'm sorry for my english
Greatings
Re: GflAx.GflAx.1 (0x80004005)
Aquiladan wrote:What I've wronged?
In line 12, what do you try to load? Are you sure that you have correct path? Is the file available on the server?
Aquiladan
Thanks, but...
Post by Aquiladan »
Thanks,
I have correct my error, the path, now and all run well.
But now I have a doubt, in the example1.asp, in the <img> tag there is this code:
<img src="image.asp?<% =file %>">
Well, I don't understand the scope of this code, can you explain me please?
Re: Thanks, but...
Aquiladan wrote:Thanks,
I'm not an ASP expert, and examples are not from me ;-)
But i think to put the original pathname
Re: Thanks, but...
I know programming but don't know ASP at all (just like Pierre). But I'll give it a try.
(Note: The ASP example is part of GFL SDK, path is .\GflAx\ASP)
-What the scripts do
Script example1 holds some visual part. Also, it calls script image.asp with the filename of an image as parameter Script image.asp opens the image, does some processing and streams it back to script example1.asp.
In some more detail:
There is two ASP scripts, example1.asp and image.asp.
- example1.asp
example1.asp is the sample page that is opened and seen by your visitors. Your code line
will call the script image.asp with the filename of an image file as parameter.
- image.asp
The script image.asp will retrieve the parameter...
File = request.querystring
...and then open the appropriate image and do some processing (add some text).
Finally it puts the image into the HTTP response:
response.binarywrite .SendBinary
Last not least, the streamed, dynamic image will be displayed in example1.asp.
More realistic sample
As written above, I'm not in ASP. But I think in a (bit) larger and more realistic sample, you would pass the filename from one script to the other using a named parameter. You can then easily pass several parameters.
The code line would then look like this:
<img src="image.asp?filename=<% =file %>">
And the code to retrieve the parameter would look like this:
File = Request.Querystring("filename")
Hope this helps.
