filelist to crash nconvert
SElsner
Post by SElsner »
i'd like to use nconvert with a filelist, but it just crashes completely on Windows (showing the dialog to send information to microsoft)
filelist has just one entry:
command line following:
nconvert.exe - v -out tiff -o "C:\#.tiff" -l C:\filelist.txt
its also not working without the -o switch
Is this a known bug, or am i doing something wrong?
converting without filelist works well.. also tried different versions of nconvert...
thanks Sebastian
Re: filelist to crash nconvert
Do you have the last version, i have no crash
Selsner
Post by Selsner »
Yes, i have the latest version, and i tried older ones too.... seems to be just a problem on one of my machines at home.... works fine on the other.... is it of any use if i send you the error report?
Selsner wrote:Yes, i have the latest version, and i tried older ones too.... seems to be just a problem on one of my machines at home.... works fine on the other.... is it of any use if i send you the error report?
Strange, it's the windows version?
SElsner
Post by SElsner »
Yes, it's the windows version... got a lot of installed codecs and graphics programms...but should be no problem, though normal converting works.
Hacker
Post by Hacker »
I confirm this using nconvert (not xnconvert), nconvert crashes when using e.g.:
c:\Programy\XnView\nconvert.exe -l "c:\Documents and Settings\Hacker\Local Settings\Temp\CMD489.tmp"
The listfile contains only one line, without spaces or any special chars.
A console window opens:
** NCONVERT v4.95 (c) 1991-2008 Pierre-E Gougelet (May  1 2008/17:48:32) **
        Version for Windows NT/9x/2000/Xp/Vista  (All rights reserved)
** This is a freeware software (for non commercial use)
then the standard "send information to Microsoft" crash dialog appears.
Using nconvert 4.95.
Roman
Hacker wrote:I confirm this using nconvert (not xnconvert), nconvert crashes when using e.g.:
And if you add for example -v ?
Hacker
Post by Hacker »
xnview wrote:And if you add for example -v ?
It is the same.
Roman
bugmenot
Post by bugmenot »
Confirming on:
Dell D820 - Core 2 Duo 1.83Ghz, 2Gb RAM
Windows XP Service Pack 3
NConvert 4.95
- Confirming with and without -o argument
- Confirming replacing -l with -L
- Confirming with 1 file listed in filelist
- Confirming with >1 file listed in filelist
- Confirming with multiple -out formats (png, gif, jpeg)
- Confirming no output with -v argument
- Cannot reproduce with existing but empty filelist
Would love this to be resolved VERY soon, as I am evaluating solutions for my employer to deploy multi-remote-site image conversion/resize batch processing, and we WILL be paying for it. This is all that stands in the way.
I am willing to work with the developers and send in crash reports/dumps if we can arrange a debug build or enable minidump output.
I will be keeping an eye on this post for the next week or so, please report back here if you're keen to get this fixed and ill register an account
Please contact me by PM or email (at xnview do com)
jmadsen
Error using listfile with -multi option
Post by jmadsen »
I can't make listfile work with -multi option. In the example below I am using new test version of NConvert, but I haven't been able to make any version of NConvert work with -multi and -L options
Works:
C:\XnView>Nconvert -in fmag -o $#.pdf -out pdf -L listfile.txt
** NCONVERT v4.98 (c) 1991-2008 Pierre-E Gougelet (Jun 4 2008/21:16:39) **
Conversion of C:\XnView\00000008.MAG into C:\XnView\1.pdf OK
Conversion of C:\XnView\00000023.MAG into C:\XnView\2.pdf OK
C:\XnView>
Doesn't work:
C:\XnView>Nconvert -multi -in fmag -o $#.pdf -out pdf -L listfile.txt
Error: This picture cannot be written using this format ($#.pdf)
Error: This picture cannot be written using this format ($#.pdf)C:\XnView>
The only option I added was -multi
I don't know if it's related to the other errors with listfile processing.
Thanks,
jmadsen
Re: Error using listfile with -multi option
Ok, it's a bug with multi
asavaris
Post by asavaris »
SElsner wrote:Hi,
thanks Sebastian
hi there,
I have the same problem too: even with a single (correct) line, the "-L <filelist>" crashes, no matter how hard I try.
In my case I used a DOS command as workaround: FOR. :)
Here it is how:
for /R %i IN (*.iff) DO nconvert -in tdi -out png -D "%i"
Now, this is the command line version. If you want to use it in a batch then the synthax changes a little: just substitute %i with %%i and you're done.
In the example above, starting from the current dir, it looks up everywhere (subdir included) for IFF and convert each one of them at time into PNGs, deleting IFFs when done (-D function).
If you want to specify a different starting location to start from, just do it right after "/R", like this:
for /R c:\mydirectory %i IN (*.iff) DO nconvert -in tdi -out png -D "%i"
I hope it helps.
asavaris
tom*de
Post by tom*de »
The "for - loop" is a good workaround, but I'd rather use nconverts v4.95 parameter -L but it doesn't work on my windows xp professional.
I think there is something wrong with this parameter.
My workaround is using unfortunately an old nconvert v4.79 ... but it works... see:
http://newsgroup.xnview.com/viewtopic.php?t=14757
tom*de wrote:The "for - loop" is a good workaround, but I'd rather use nconverts v4.95 parameter -L but it doesn't work on my windows xp professional.
Do you have tried the 4.98?
