View images only
Filter by...
View images only
Post by Filter by... »
Hi
I have a slight problem with the View mode. I would like to set it to open image files only. I know there is a filter by function but the problem is, when opening directly in view mode (not the browser) it ignores the filter I've set in the browser mode. When i open the browser mode, then switch back to view mode, the filter activates. Also, there's no way to set Filter by is view mode, you have to go back to the browser.
Is there any way to fix this?
You have my thanks in advance
Re: I would like to wiev images only
Filter by... wrote: I have a slight problem with the View mode. I would like to set it to open image files only. I know there is a filter by function but the problem is, when opening directly in view mode (not the browser) it ignores the filter I've set in the browser mode. When i open the browser mode, then switch back to view mode, the filter activates. Also, there's no way to set Filter by is view mode, you have to go back to the browser.
You means view only images in view mode by using PgUp/Down?
Filter by...
Yes, exactly.
Filter by... wrote:Yes, exactly.
And do you have changed the 'show in preview' column in option/file list?
Filter by...
I changed it, and it seems to affect only the way browser plays it, and not the view mode itself - I PgUp/Down to it and it will play.
Filter by... wrote:I changed it, and it seems to affect only the way browser plays it, and not the view mode itself - I PgUp/Down to it and it will play.
And which files do you view in view mode? Video?
same as above
Post by same as above »
I would like to view IMAGES, and skip videos and audio files. The problem happens only when i scroll and only when i got to View mode directly, otherwise i just apply the filter for images.
same as above wrote:I would like to view IMAGES, and skip videos and audio files. The problem happens only when i scroll and only when i got to View mode directly, otherwise i just apply the filter for images.
When you scroll in view mode?
Do you have tried to disabled too option/View/Misc/Play video
same as above
Yay, it worked :D Thanx a lot man, tis program is awesome, I'll recommend it to everyone.
Also, one more thing. I seem to be receiving a "APFL Ghostscript not found on your system" error when I'm browsing. What could be the cause of this?
Once again, thank you in advance! I must be boring the crap out of you
same as above wrote: Also, one more thing. I seem to be receiving a "APFL Ghostscript not found on your system" error when I'm browsing. What could be the cause of this?
It's for PDF
