Unable to full screen on a secondary screen
Post by Guest »
Xnview always go full screen on the primary screen, even if launched on a secondary screen.
foxyshadis
Post by foxyshadis »
You have to check the option to use full screen on the secondary monitor, in the full screen options. xnview doesn't check which monitor the browser is running on, only that option.
Post by Guest »
Ok Thanks!
Any chance it detects automatically in the future?
I often swap applications between my two screens :?
