Hi
I ran a search for this question, but came up with a lot of old answers.
Is this feature available in the new version?
Regards
Can You edit the IPTC data of TIFF files yet?
Re: Can You edit the IPTC data of TIFF files yet?
Nocamel wrote:Hi
Re: -
Oh, fill some fields with some other fields?camel wrote:For JPEG's. I want to put the filename into the IPTC field.
I have a set of files, and I will rename them all, but I want to keep the old filenames in the IPTC data.
How can I do this?
Thanks for your prompt responses to my questions!
camel
-a
Great program.
These are two features that I think would make the IPTC experience easier.
1) add filenames to a selected IPTC field.
2) interchange IPTC fields. I.e. you can make headline = object name, or headline ="description".
3) editing the IPTC of Tiff files.
Thanks for your very prompt response Pierre, and I think that this is an amazing program. Slowly finding my way around it!
