Request: Separate control over folder color updates.
JohnFredC
Post by JohnFredC »
I would like to use the folder colors options to color my each folder thumb differently based on color schema I have constructed.
However, the new folder thumbs update behavior not only changes the 4 "little" thumbs on the folder, it also updates the folder colors to the current settings.
Please enable a method for the folder colors to persist.
Ideally I would like to right click on a folder and select from list of folder color schema, then have the color scheme of each individual folder persist until I change it manually.
Thanks for listening!
John
Re: Request: Separate control over folder color updates.
JohnFredC wrote:I would like to use the folder colors options to color my each folder thumb differently based on color schema I have constructed.
ok, so i need to store the list of customized folder and the color...
JohnFredC
Post by JohnFredC »
xnview wrote:ok, so i need to store the list of customized folder and the color...
Sorry, everything I suggest for XnView grows tentacles like an octopus...
8)
John
