I've managed to make it works fine under xp64.
Now, just wondering if there's a chance to use it on xplorer2 as well.
Since the shellExt works fine in explorer, but not in xplorer2: I think it's due to the native 32bit of xplorer2...
So, I'm just wondering whether there's a workaround for this.
Thanks in advance for any help.
shellExt x64 now even more difficult
NSX82
Re: shellExt x64 now even more difficult
Hi!
I have a same question..
I use an different 32 bit file manager under Win7 64Bit.
If I install the 32 bit version, it works only uner 32 bit apps and overwrites the 64 bit version. Or if I install the 64 bit version it works wit 64 bit apps but overwrites the 32 bit version... Is there any possibility to install both of Shellext under an 64 bit system? It will be very usefull even if the programs have two different settings.
Greets: Karoly
Greets: Karoly
Ok, you can rename the 64bits version and register it. I'll change the package...
NSX82
Hi!
Thank You very very very much this modification!!!
It's helps me a lot!
btw:Sunday was my birthday, so its a kind of birthday gift for me
You are COOL!
Greets: Karoly
You are COOL!
Greets: Karoly
