Batch rename - wrong sort order
Post by Guest »
Hi!
I am using the batch rename feature with sorting by date. A problem occurs when several images have exactly the same time stamp which occurs when shooting a series of images, for example to capture some sports scene. In this case, the sort result is wrong. However, the correct order is included in the file names like DSC_1678, DSC_1679, DSC_1680 and so on.
I think XnView should sort files with the same time stamp by their file name by default.
Regards
Incendio
Re: Batch rename - wrong sort order
Anonymous wrote:Hi!
Regards
Incendio
Do you use the popup menu to sort list?
