hi xnview
with the register.bat in the new zip installation i´m now able to see the thumbnail preview in 64bitexplorer in xp64bit...
but if i click on the thumbnail xnview doesn´t start to open the picture...
any little thing that i missed to click here?
....btw is it possible that it opens multiple instances of xnview for multiple pictures i want to look and compare...like in old picaview...
thanks xnview
thomes
click on explorer thumbnail doesn´t start xnview...
- Forum Librarian
xnview ([url=http://newsgroup.xnview.com/viewtopic.php?p=16903#16903]Can't view JPG file by using XnView[/url]) wrote:There is a bad key in registry, please remove -slide from:
HKEY_CLASSES_ROOT\Applications\xnview.exe\shell\open\command
"C:\Program Files\XnView\xnview.exe" -slide "%1"
Correct is:
"C:\Program Files\XnView\xnview.exe" "%1"
Note: Your program path may differ, keep your program path.
First something to clarify:
Are you talking about the thumbnails in XnView browser or MS Explorer (Shell extension)?
If it's XnView: There might be a "wrong" XnView setting. Could you please try the following:
1.) Exit XnView
2.) In MS Explorer change to folder C:\Program Files\XnView
3.) Rename file "xnview.ini" to "xnview-bak.ini"
4.) Start XnView
Now please check, whether the problem persists.
1.) Exit XnView
4.) Start XnView
caninus
Clicking on MS-shell-extension-preview does not start Xn-Vie
I have the same problem :
clicking on thumbnail preview in MS-Explorer started automatically Xn-View.
This was working in earlier versions, could not find the menu entry for correcting this, if there is any.
Is there any help ?
Thank you.
Is there any help ?
Thank you.
