Illustrator Image display cutoff in Xnview
Post by Guest »
This is an A3 size AI file created using Adobe Illustrator CS.
Resized for web viewing.
In the above pic , it only display half of it in Xnview. The other half which is the left hand side of it is cutoff.
Why is the image cutoff in half when view under Xnview.
There is no problem in viewing using Illustrator.
Or the source file is damage.
:shock:
Re: Illustrator Image display cutoff in Xnview
Anonymous wrote: This is an A3 size AI file created using Adobe Illustrator CS.
:shock:
Is it possible to send me the file?
