1.92 Print multiple images - footer and captions collide
dietmarrudolph
Post by dietmarrudolph »
using 1.92 on WinXP:
When printing many images onto the same sheet (in German that's Print -> Layout -> "Miniaturansicht"), the array of images and captions on each full page completely fills the page area, i.e. the space between the selected borders. OK.
However, if you add a page footer to your page, this footer is placed BETWEEN the page borders. This results in the footer being printed into the same area as the lowest captions making both unreadable.
Re: 1.92 Print multiple images - footer and captions collide
dietmarrudolph wrote: However, if you add a page footer to your page, this footer is placed BETWEEN the page borders. This results in the footer being printed into the same area as the lowest captions making both unreadable.
The footer is printed on the border???? On the preview all is ok?
dietmarrudolph
xnview wrote:The footer is printed on the border???? On the preview all is ok?
Pierre, the footer is printed inside the border, i.e. over the lower border. Both in the preview and in the printout.
