XnView 1.92 is only displaying the first character of any EXIF - Image - User Comment I put into the EXIF - Image - User Comment field.
If I put the comment into the EXIF - File - Comment field, it displays fine.
My problem is that I have thousands of comments inserted into the EXIF - Image - User Comment Field which I would love to be able to view in XnView.
Any
Magnificant program. Well done.
Tex
1.92: EXIF Image - User Comment display issue:
Re: XnView1.92 EXIF Image - User Comment display issue:
Could you send me a sample, please?Texmax wrote:XnView 1.92 is only displaying the first character of any EXIF - Image - User Comment I put into the EXIF - Image - User Comment field.
Any
Tex
TexMax
Example sent:
Hi Pierre. Thanks for your response.
I am not sure how to post a picture here, so I have sent an example to your email address: *****.
It is a jpg that shows Windows Properties, ACDSee9 Pro & XnView all displaying the same EXIF User Comment Comment. As seen, XnView only displays the first charater if the sentence, while the other two display the entire senence that I added.
You may be able to replicate the problem yourself by adding a comment in Windows Properties to a jpg and then viewing the user comment in XnView.
I will send the pic to you now.
Thanks.
Tex
EMail address removed by moderator to avoid the robots. Please use
Thanks.
Tex
Re: Example sent:
Do you use
Re: Did you get the email Pierre?
No, not received itTex wrote:Just wondering, did you get the email Pierre?
Tex
