Would it be possible to have a batch edit feature for RAW EXIF data?
Problem: I have two or three hundred or so Sony *.ARW images that need to have the EXIF time stamp changed by a factor of 8 hours only. (I forgot to reset the camera time when I arrived in China). The 'Change Timestamp' facility only works for jpeg EXIF or RAW Properties not RAW EXIF and one can only process one image at a time.
Can you please help?
Or alternatively, could you recommend suitable software?
I would prefer to keep all my image manipulation in Xnview.
Regards
Alan
Batch edit of RAW EXIF
Re: Batch edit of RAW EXIF
Yes, i'll try to add itAlan wrote:Would it be possible to have a batch edit feature for RAW EXIF data?
Regards
Alan
