wrong filesize for big files (2, 3, 4 GB files...)
nightbeholder
Post by nightbeholder »
When I click in some files I have that are about 3 GB the filesize in the status bar as well as in the properties is completely wrong and in some cases it just doesn't show at all...
meRobs
Post by meRobs »
This bug affects me a lot!
It will affect anyone dealing in video files. A DVD holds 4.7 to 9 GB (as VOBs) and the biggest elementary stream in a VOB is an M2V file. Its size displays correctly up to about 1.3 GB only.
When video is captured to a quality AVI its size would be 13 GB per hour. So, files of 30 GB are easily seen. Unfortunately, XnView 1.92 displays the size correctly only up to about 2 GB. Above that the size becomes progressively smaller even negative (on Properties tab) and then nothing is shown in the Size column.
Under Options I have 9999999 kB, the max.
Hope this bug can be removed soon!
