REQST: Propose currently viewed file for Batch Convert
JohnFredC
Post by JohnFredC »
In the Browser, one can select a file or files, then go to Tools->Batch Convert and find the selected files by default already in the file list.
In the viewer, however, after opening Batch Convert, the current file (ie. the file in the active tab) does not appear by default in the Batch Convert file list.
It would be great if Batch Convert "picked up" the file (in the current tab) the same way it "picks up" the selected files in the Browser.
Thanks for listening!
John
Re: REQST: Propose currently viewed file for Batch Convert
JohnFredC wrote:In the Browser, one can select a file or files, then go to Tools->Batch Convert and find the selected files by default already in the file list.
Yes right!
You can add cmd_FileOperation to view toolbar to have 'batch current file'
