Crash with mov files
usuario
Hello from Spain and sorry by my bad english.
I have a bug:with the program in the display mode: I have some jpg and mov files in a folder. When I view the pictures all is correct, but when the next file is a mov file, the program crash and get out to the desktop.
Is there any solution?
Thanks and Bye.
Thanks and Bye.
Re: Crash with mov files
Your movies are only in mov format? which OS?usuario wrote:Hello from Spain and sorry by my bad english.
The mov file can be viewed in xnview?Anonymous wrote:Hello again.
I use xp professional SP2.
I have too mpg files at the same directory, and I Haven´t any problems with them. Te mov files are record with a Nikon coolpix 2200 camera.
Thanks for the interisting.
The program is very good except this problem. Do you think any solution?
Bye.
Cyrlaur
RavyDavyGravy
RavyDavyGravy
stanli
I have The same problem
but I have an another question. Is there any way to disable loading mov files?
At file associations tab there is no mov file type, so I can't switch it off and at prewiew tab I have disable "autoplay for video and audio" and "show first frame for videos" option, but XnView still try to open it and crashes.
I am using XP Home and K-lite mega codec with quicktime player alternative.
Re: I have The same problem
Try to open it when you click on it?stanli wrote:but I have an another question. Is there any way to disable loading mov files?
Kepa
DirectX aceleration problem
Hi!
Sorry my poor english too!
I have the same problem with a lot of versions of xnview and Quicktime (And QtPro) I only want to notice that if you disable the video accelerations (at Quicktime preferences->Video preferences), then the xnview not crash...
Thanks!
Kepa.
Thanks!
Kepa.
