ZoomLock not saved
veggen
ZoomLock not saved
Post by veggen »
I'm using XnView 1.92.1 and from what I understand, Lock Zoom option should be saved between program restarts ie. if Lock Zoom is enabled once it should stay enabled the next time I open the program. However, this is not happening. I tried opening xnview.ini and changing LockZoom to 1, but this doesn't seem to help. Any ideas?
Thanks for the time.
Other entry
:arrow: veggen
:) Hello !
• Please, see if you have :
LockZoomFlag=1
(Restores the old behaviour…)
- Set it as :
LockZoomFlag=0
• Pierre added that entry because I reported a bug with the new behaviour you wish,
when starting image-files from a file-manager under certain conditions. ;)
:mrgreen: KR
