How to strip alpha channel
krawhitham
Post by krawhitham »
Basically I have 32bit PNG images and would like to convert to 24bit BMP images.
The alpha channel is blank and not needed any way to remove the alpha channel using nconvert
Re: How to strip alpha channel
krawhitham wrote:Basically I have 32bit PNG images and would like to convert to 24bit BMP images.
You can use -truecolors
