Create Web Page
frred
Create Web Page
Post by frred »
I am having trouble with the "Create Web Page" command.
"_default-Frame" is the only template that works. All the other templates just create a blank web page. It puts all the pics in the image and thumbnail directories, but the page comes up blank. When I look at the size of the html file created, it shows 0kb.
What can I do to fix this? I have latest version, I have downloaded again, and installed on a second computer (both run XP Pro with SP2).
THANKS!
It's a known bug. Pierre says “it will be fixed in a 1.92.2”.
frred
Post by frred »
duh, bad on me...I looked around for posts with the same problem first, didn't see that one.
Thanks for helping.
XnView is a GREAT product -- I've been looking for a good (and fast) image viewer to help sort thru all my pics...XnView is it!!!
