1) Open a file with XnVew
2) Switch to fullscreen
3) Open another file from «outside», for example:
Win+R, Enter, «c:\bin\xnview.exe c:\file.jpg», Enter
4) the existing instance of xnview closes silently, so none file is viewable now, as result
Windows XP SP2, XnView 1.92.1
Set up "Only one window view opened" in options
Crash opening a file while another is opened in fullscreeen
OK here
• I cannot reproduce that here with the same settings (and only one instance of XnView ticked).
- When in full screen like you say, I switch (Alt+Tab) to Total Commander from wich I start another image file, it's opened OK.
XnView 1.92.1 - Xp-Pro SP1 (Fr)
The two OK
—> helmut
Hi !
• I tested the two modes, from “View” and from the browser, no crash…
But sometimes from the browser, the Full screen can't be removed with F11, I had to use Esc instead…
G.
