CTRL+W Close the program!!
Hend217
Post by Hend217 »
CTRL+W closes the program instead of the active archive (image), like it used to be in older versions.
CTRL+W = CTRL+Q (?)
Fix it please!! :(
hend217
more info
Post by hend217 »
ops I forgot, this happens in the version -> XnView v1.92.1 on Windows XP PRO SP2
ckit
Post by ckit »
For me, both CTRL+Q and CTRL+W close the active window.
Neither, exit XnView!
We do have a bug here!
OUCH !
:) Hello !
• I can confirm, Ctrl+W closes the programme, so we have a
Image :D
:mrgreen: KR
Troken
Post by Troken »
Confirmed.
Do you have tried to change option/keybooad/Single ESC...
Troken
Post by Troken »
xnview wrote:Do you have tried to change option/keybooad/Single ESC...
Have not done that. It still closes the program, it doesnt matter which choise I select.
No matter
:arrow: Pierre
:) Hello !
• Like Troken points out, the setting of the single click behaviour doesn't matter (why should it do ?).
- I've set it as “Never”, and Ctrl+W closes the programme still !
:mrgreen: KR
Hend217
does not work
Post by Hend217 »
I tried this, and does not work
CTRL+W closes all the program. It must be close only currently image.
1- Before close the currently image.
http://ciudad.latinol.com//hendrick/img01.png
2- After ctrl+w keys (or menu "File" - "Close"). If don't have more active images:
(Screenshots generated with Xnview V1.82.4) :wink:
hend217
screen
Post by hend217 »
ops!, the second screen XD:
http://ciudad.latinol.com//hendrick/img02.png
:p
Re: screen
Oh yes, it was a request between 1.91 beta. Close or Ctrl+W must close xnview if there is no more opened tab/image
Ini, Ini plz !
:arrow: Pierre
:) Hello !
• But that's not satisfactory for all users…
- For instance, we would want to close the current image, keeping the main View window open,
in order to D&D a file from another application, come back to the browser via its button or whatever else…
- Maybe an INI entry to configure that behaviour, please ? ;)
:mrgreen: KR
Hend217
Re:
Post by Hend217 »
xnview wrote:Close or Ctrl+W must close xnview if there is no more opened tab/image
xnview 1.92.1 closes the program with o whitout images loaded. Only ask if you want save when have any opened image, and close the program. Same that CTRL+Q
Misbehaviour
:arrow: Hend217
:) Hello !
xnview 1.92.1 closes the program with o(r) whitout images loaded. …
• That's right, and doesn't match the changed behaviour that Pierre refers to. Hence, there is a :bugconfirmed: really.
- Currently, the only way to keep an empty “View” window when closing the last image is to use the Win [x] lower button.
…Only ask if you want save when have any opened image, and close the program.
• That's disabled here from INI ENTRIES.
- BTW, it might not ask to save an image you didn't change at all…
Same tha(n)t CTRL+Q
• Exactly !
:mrgreen: KR
Hend217
Re: Misbehaviour
Post by Hend217 »
Clo wrote::arrow: Hend217
Sorry for the bad spelling.
but...
Mi idioma en realidad es español :wink:
I understand a little english.
Bye :mrgreen:
