Batch convertion with nconvert
Volker
Post by Volker »
Hi all,
I have the following issue. I have created a batch file which allows me in a very simple way to convert any format into the jpeg format.
Does a command line parameter exist which allows me to write the result of the convertion into a txt file? :shock:
I have not found anything.
Thanks for you help!
Volker
Re: Batch convertion with nconvert
Volker wrote:Hi all,
You can use > redirect
Volker
redirect hint
Post by Volker »
Hi Pierre,
thanks for your help. But this creates only a txt file with your copyright information.
Regards, Volker
Re: redirect hint
Volker wrote:Hi Pierre,
And 1>
Volker
I have got the same result
Post by Volker »
Hi Pierre,
I have tried the following:
nconvert -log -out jpeg -truecolors c:\photos\photos\*.gif >c:\photos\test.txt
And I have got the following result in the test.txt:
** NCONVERT v4.86 (c) 1991-2007 Pierre-E Gougelet (Jan 29 2008/13:24:04) **
Version for Windows NT/9x/2000/Xp/Vista (All rights reserved)
** This is a freeware software (for non commercial use)
Thanks, Volker
Re: I have got the same result
Thanks, Volker
Try nconvert -log -out jpeg -truecolors c:\photos\photos\*.gif 1>c:\photos\test.txt
Volker
I have got the same result as before
Post by Volker »
any ideas?
regards, Volker
Re: I have got the same result as before
Volker wrote:any ideas?
Do you have tried my solution?
Volker
log file
Post by Volker »
Hi Pierre
yes I have tried it with the same result:
content of my .bat file:
nconvert -log -out jpeg -truecolors c:\photos\photos\*.BMP 1>c:\photos\test.txt
content of test.txt afterwards:
Thanks for your help!
regards, Volker
Re: log file
Try 2>
Volker
Log file
Post by Volker »
Hi Pierre,
2> works!
Thx, Volker
