Related to the bug report about cbz, i collected the things that might be neccessairy to get XnView to handle CBZ/CBR files properly. I guess it's low priority, but in case it's ever tackled, maybe this list makes it easier to find the points that need addressing.
- Even though their internal structure is that of an archive, cbz/cbr files would need to open in the associated program/exernal viewer via double click, unlike normal archive types. Thats because they don't need to be browsed from withing XnView, since they are handled by dedicated viewers.
- cbz/cbr files would need to be known by XnView to be archives, so that the first image is actually decompressed for a thumnail creation. Right now, XnView displays a thumbnail only by accident: if zip file format was used, but no compression applied when creating the cbz.
- Unlike normal archives, the thumbnail should rather be like with normal images, not as with folder/archives. That means, only 1 image, and no folder icon in the background. The cbz/cbr format stores comic books, which are identifiable mainly by their cover.
- XnView would need to also look in subfolders for cbz/cbr files and display their thumbnails as folder overlays, like it does with images.
Greetings
maraskan_user
CBZ/CBR file type thumbnail support
maraskan_user
Return to “Classic - Suggestions”
Jump to
- General
- ↳ Info & Forum
- ↳ XnView - FAQ
- ↳ Miscellaneous
- XnView MP
- ↳ MP - Announcements
- ↳ MP - General Support
- ↳ MP - Bug reports
- ↳ New
- ↳ Reproduced - TODO
- ↳ Fixed in next version
- ↳ Retest
- ↳ Postponed
- ↳ Closed/Resolved
- ↳ MP - Suggestions
- ↳ MP - General [Français]
- XnView Classic
- ↳ Classic - General Support
- ↳ Classic - Bug Reports
- ↳ Classic - Suggestions
- ↳ Classic - General [Français]
- XnView Family
- ↳ XnConvert
- ↳ XnResize
- ↳ XnRetro, XnSketch, ...
- ↳ NConvert
- ↳ XnView Shell Extension
- ↳ Android & iOS: XnPhotoFx, XnRetro, XnSketch, ...
- ↳ XnView Pocket
- ↳ GFL SDK
- Contribution
- ↳ Customization
- ↳ Documentation
- ↳ XnView MP - Translation
- ↳ XnView Classic - Translation
- ↳ Testing - Closed/Solved
- ↳ 1.96 Testing - Feedback
- Archive
- ↳ XnView Un*x
- ↳ XnView Mac OS X
- ↳ Classic - Resolved Bugs & Requests
- ↳ MP - Resolved Bugs & Requests
- ↳ MP – Beta Testing
- ↳ New
