Debut - Freeware
Homepage
Debut Video Capture Software
Record video from webcam, capture devices or screen
Debut is a simple, easy to use video recorder that lets you capture video files directly on your PC using a webcam (video camera), or capture device (from video). This software can also capture and record almost anything that can be played or displayed on the computer screen. The program saves the video on your hard drive as avi, wmv or many other file types.
This video capture software is completely free.
Designed to be very easy and intuitive to use, Debut will have you up and running, ready to record video within minutes. Simply download now and install. We make Debut free in the hope you will like it so much you will try our other Video Software.
Features:
Records video in many different file formats including .avi, .wmv, .asf .mpg, .3gp, .mp4, .mov and more
Ability to record from:
Camera (webcam)
Video Input Sources with a USB Capture Device see here...
Screen. Almost anything you can see or play on your PC can be recorded.
Records audio with the video (optional).
Multiple video and audio encoder settings.
Ability to adjust resolution and framerate of the output video.
Color settings for the output video can be changed.
Lets you record for set specified durations (h:mm:ss).
When recording period is over, you can either stop recording or create a new recording and continue.
Mirror recordings to a network or backup drive to keep your video files safe.
Can be set to automatically send video via email once the recording is completed.
Can automatically transmit video files via the internet using FTP.
Find and play recordings ordered by name, date, format or size
Ability to burn directly to DVD with Express Burn Plus.
System wide hot-key assignment to control recording while working in other programs.
Debut Video Recorder has an incredibly intuitive and easy to use interface.
Compatible with BroadCam Streaming Video server to distribute your recording.
System Requirements
Windows 98/2000/XP/2003/Vista
[Optional] Webcam with Windows Drivers
[Optional] USB Video Capture Device
Debut - Freeware
