TightVNC (opensource freeware)
All non-XnView related: softwares, formats, imaging, photography...
ckv
Post by ckv »
TightVNC is a free remote control software package derived from the popular VNC software. With TightVNC, you can see the desktop of a remote machine and control it with your local mouse and keyboard, just like you would do it sitting in the front of that computer. TightVNC is:
  • free, GPL-licensed, with full source code available;
  • useful in remote administration, remote customer support, education, and for many other purposes;
  • cross-platform, available for Windows and Unix, compatible with other VNC software.
http://www.tightvnc.com/
ckv
Re: TightVNC (opensource freeware)
Post by ckv »
TightVNC 2.0 Beta 1
First beta of TightVNC 2.0 has been released.
This Beta version delivers completely new TightVNC Server for Windows. It was redesigned and reimplemented from scratch. It features new component-based architecture which is perfectly compatible with the latest operating systems, Windows 7 and Windows 2008 Server R2. Older versions of Windows are supported as well – the minimum requirement is Windows 2000.
http://sourceforge.net/projects/vnc-tight/
