XnView 1.92.1.0 and .djvu files
gaetano_gatto
Post by gaetano_gatto »
Hi folks!!
I've dowloaded XnView (Windows version) from here: http://pagesperso-orange.fr/pierre.g/xn ... nload.html
...but I've tried to open .djvu files with the program and it sends me a warning as: "It is unknown how to read XXXX.djvu".
Could anybody help me?
PS: I've installed all indicated features of the program. :?:
Pkug-in needed
:arrow: gaetano_gatto
:) Hello ! Welcome aboard !
• Like it's indicated HERE, *.DJVU needs a plug-in, there is no built-in support.
- So, you have to download the plug-ins pack and unpack it into the <Plugins> sub folder of the programme.
:mrgreen: Kind regards,
gaetano_gatto
Hello!! Thanks for welcome..
and a thousand of thanks for your help..what an absent-minded I am!! :mrgreen:
gaetano_gatto
Perhaps I'm uncapable...I've just done everything you said me (dowload and unzip) but I've the same problem...
I've download All_Plugins pack from here: http://pagesperso-orange.fr/pierre.g/xn ... ugins.html
..where am I wrong?
Restart ?
:) Again…
… …where am I wrong?
• Please, check if you have a file <Xdjvu.dll> among the ones you installed.
- Here, it's so big, ~ 0.9 MiB.
• Did you try to restart XnView, then attempt to display your file¦s again ?
• Finally, it should be useful to get one file of yours to test. You may place one @ an image host
(if you can't place it in a personal web folder).
- See i.e. : In browser mode >> Tools menu >> Plugin >> ImageShack.
:mrgreen: KR
FAQ "Does XnView support graphic format .xyz?" provides various information regarding supported formats and plug-ins.
gaetano_gatto
Re: Restart ?
Clo wrote:
• Please, check if you have a file <Xdjvu> among the ones you installed.
Yes, there is.
Clo wrote: • Did you try to restart XnView, then attempt to display your file¦s again ?
I tried it but the problem is the same.
• Finally, it should be usefull to get one file of yours to test. You may place one @ an image host
(if you can't place it in a personal web folder).[/quote]
I can't place one of these files on web because they represents commercial books...Do I have to send it by mail?
But, is the pack of plugins I've downloaded complete with all plugins developed for XnView? :(
Option…
:) Hi !
• Please, check the option General [Operations] [×] Display all image file types, it must be ticked !
…But, is the pack of plugins I've downloaded complete with all plugins developed for XnView? :(
• Normally yes, at least for your issue.
:mrgreen: KR
gaetano_gatto
Re: Option…
Yes, it is ticked.. :(
Re: Option…
Not all versions of DjVu are supported
gaetano_gatto
I've uploaded the file to open on http://www.transferbigfiles.com/Get.asp ... 509e2b4551
could anyone suggest me how to open it?
Thank you!! I'm becoming mad.
I can't
:) Hello :
…could anyone suggest me how to open it?
• I've downloaded your sample, and I can't open it either in XnView :|
• Only Pierre can say whether that variant of DJVU could be added to the supported formats,
maybe via another plug-in DLL, he's the expert at this…
:mrgreen: KR
gaetano_gatto wrote:I've uploaded the file to open on http://www.transferbigfiles.com/Get.asp ... 509e2b4551
This sample can only be loaded by DjVuLibre, but this library is in GPL, so i don't know if i can use it
Post by Guest »
Excuse me for my ignorance, do you mean General Public License with GPL?
Will XnView be ever able to open a file like that some day?
Anonymous wrote:Excuse me for my ignorance, do you mean General Public License with GPL?
Yes
I don't know yet, i'll make some search
