RFE: Folder Pane & Some more Windows Shell Integration..
MaierMan
Post by MaierMan »
hi again,
Im currently re-installing my system, and I took XNView as my default image viewer/browser.
(throwing away ACDsee :P)
There are some... ummm... "annoyances".
First, the only thing you could do with the folder pane is selecting a folder.
It would be great if drag/drop move/copy, deletion, a context menu and such stuff were available as well.
That brings me to the 2nd thing.
Most other applications of this kind allow showing the Windows Shell Context Menu
(eg. wenn right clicking on a file/folder while holding Shift and/or Ctrl Key)
by utializing the IShellFolder::GetUIObjectOf and IContextMenuX COM interfaces.
This feature (depending on your sources/build-structure) shouldn't be that hard to integrate (done such stuff myself),
thus I'd like to kindly request it for an upcoming version :D
Another thing is Drag/Drop DropSource support for the folder (pane)
(corresponding to what I mentioned above).
You appearently implemented IDropSource stuff for the file-list (files) already... it would be great if you made it available for the folders (pane) too.
[Edit]
Almost forgot.
Giving the Mouse XButtons (WM_XBUTTONxxx) some functionality would be also great indeed.
(Like Prev (Back), Next (Forward) functionalities)
Just suggestions ;)
Keep up the great work (hehe, egoistic, isn't it?)
Nils
Dreamer
Re: RFE: Folder Pane & Some more Windows Shell Integrati
Post by Dreamer »
MaierMan wrote:First, the only thing you could do with the folder pane is selecting a folder.
Yes, it's a known problem, but it's very annoying, maybe even a biggest xnview issue - copy and move folders.
(delete and rename are possible)
