KD Player - for your mobile phones (java) - SE, Nokia etc..
All non-XnView related: softwares, formats, imaging, photography...
budz45
Post by budz45 »
KD Player v0.91 Beta English Version (J2ME - mobile cell phone java).
The last stablke version is version 0.89
KD Player is a free J2ME based audio player created by Russian developer Knyzhov Dmitry. It is designed for mobile phones running Operating System Embedded platforms. The program can playback audio files that are supported by the phone model, most commonly mp3 and wav files which the program fully supports. KD Player can be downloaded depending on screen display resolutions that your mobile phone would support. The current resolutions available are in the 128x160 , 176x220 and 240x320 size formats. The software was developed with the idea of replacing the standard media player found on many modern phone's as described in the author's description. Playback options include Play, Volume Control, Fast Forward, Rewind, Shuffle and two Repeat modes (playlist repeat and single track repeat). In addition KD Player supports full reading of ID3-tag data and the sorting of tracks by album, artist or track title.
Since the latest test version of 0.91 improvements have been to add the feature of the 'scrolling' of long tag names and increased support for more phones brands including Nokia and Motorola. A changelog for KD Player's versions can be found on the official website.
OFFICIAL INFO
http://www.easter-eggs.net.ru/KDPlayer/EN_Versions.htm
DOWNLOAD latest (v0.91) translated from English - Rapidshare or Sendspace
240x320 screen size
http://www.sendspace.com/file/y8771n
or
http://rapidshare.com/files/88713991/KD_Player_v0.91_Beta3_240x320_ENG.jar.html
176x220 screen size
http://www.sendspace.com/file/66ebk1
or
[b]http://rapidshare.com/files/88905723/Eng-Beta-KD_Player__v0.91__176x220.jar.html
Places to download free skins
http://www.esnips.com/web/KDSkinned
http://forums.se-nse.net/index.php?showtopic=17081
budz45
Post by budz45 »
Requirements:
· JSR-75 / JSR-135
· Tested on: Sony Ericsson W810, K800, Z710 ; Nokia S40: 5300, 6233, S60: 5700
Instructions:
1. Download .jar file (which is the installer)
2. Send to your phone the way you would send any normal file (usb, bluetooth etc.)
3. Run the file on your phone and install
4. To import music you must goto the main menu > preferences > folders for scanning
5. You must always safely exit application via the 'exit' in the application's menu otherwise when you start the application again you will loose all your playlist and tracks
EnJOY this application as I do on my Sony Ericsson K850 :) :)
ZoNi
Post by ZoNi »
I will try this one, as I see it has now support for 208x208 (as in mine Nokia 6230i) :)
Post by Guest »
budz45 wrote:Requirements:
· JSR-75 / JSR-135
Instructions:
2hard2handle
the skin wont work
Post by 2hard2handle »
the skins wont work on my nokia 5300!
Krishna
I couldn't able to listen on w810i
Post by Krishna »
I have installed KD player on w810i. It is working. But when I play the song, voice is not audible....Even no clue of any sound. I can see only playing songs. Could you please help me to sort out this....
I desperately want to see playing music in this player as I am not able to watch any video on my w810i.....
Regards,
Krishna
