Customizing colors of file tree pane
foxyshadis wrote:I'm curious, was any color ever added for the selected file's background/font? That's one of the only colors in the program that still seems to be the system default.
To my knowledge there are now four INI entries for customizing the colors of the folder tree pane.
Can anyone confirm that TreeFontHiColor is ignored if set to 100% black (0/#000000)?
  1. TreeBackColor=#666666
    TreeFontColor=#CCCCCC
    TreeFontHiColor=255
    » red
    TreeFontHiColor2=16777215
  2. TreeBackColor=#666666
    TreeFontHiColor=0
    » TreeFontHiColor = TreeFontColor :?
  3. TreeBackColor=#666666
    TreeFontHiColor=1
    » R1/G0/B0
Does nothing---
:arrow: XnTriq
:) Hello !
• Maybe a bit aside, here I've :
TreeBackColor=255 255 222
TreeFontColor=60 0 0
TreeFontHiColor=180 0 0
TreeFontHiColor2=#00F000
…but I never see any “green” in the tree.
- All other entries work as expected, though…
:mrgreen: KR
Thanks for checking, Clo.
Something's not kosher in the way these settings are interpreted by XnView v1.92.1, but for now I can't narrow the problem down any further.
Kosher or not… That's the question !
:arrow: XnTriq
:) Hello !
Something's not kosher in the way these settings are interpreted by XnView v1.92.1…
• Yes, “pas très catholique…”. :D
That's pretty annoying because we need to update the Manual about the “TreeFontHiColor=…¦TreeFontHiColor2=…”
and that's impossible till Pierre explains clearly what the “2” entry might do.
- There is nothing in the <What's new>…
:mrgreen: KR
Oops, pardon my Yinglish. I forgot we're a catholic network. Mea culpa. :wink:
This seems to be the thread where the feature was originally requested:
ghost zero ([url=http://newsgroup.xnview.com/viewtopic.php?t=13204]TreeFontHiColor2 option?[/url]) wrote:How about adding a TreeFontHiColor2 option? So both active and inactive pane text color can be seen?
Nope…
:arrow: XnTriq
:) Again…
• Sorry for this expression but it's the very orthodox French translation for “not kosher:P
• The ghost zero's pics are clear, but here nope ! Active and inactive panels have different BGs like they would,
but the font-colour stays the same, while IIUC it might be green for the inactive panel. :bug: ?
    Image      Image
• I used TreeFontHiColor2=0 240 0 for the test shown above, no progress.
:mrgreen: KR
    TreeFontHiColor=255
    » red
    TreeFontHiColor=0
    TreeFontHiColor=1
    » R1/G0/B0
Yes right, it's to know if this entry exists (TreeFontHiColor & TreeFontHiColor 2). I'll fix it
semi-fixed
:arrow: Pierre
:) Hello !
• Now in 1.93ß1, I get all colours but the entries are inverted with regard to the images above :
TreeFontHiColor=180 0 0 >>> Stands for INactive panel,
TreeFontHiColor2= #00F000 >>> Stands for Active panel !
:mrgreen: KR
Re: semi-fixed
Clo wrote::arrow: Pierre
:) Hello !
:mrgreen: KR
Right :-(
Re: semi-fixed
Clo wrote:• Now in 1.93ß1, I get all colours but the entries are inverted with regard to the images above :
Fixed in beta 2.
Changed again--
:arrow: XnTriq
:) Hello !
• Confirmed OK now, I'd just to invert my values again… :D
:mrgreen: KR
Post by Guest »
Hi, i looked all through the .ini file and cannot find these in the file to change them. Do I have to add them manually, and if so under what section?
Anonymous wrote:Hi, i looked all through the .ini file and cannot find these in the file to change them. Do I have to add them manually, and if so under what section?
You have to add them manually to the [browser] section.
dragonsblade71uk
Post by dragonsblade71uk »
Ok ty, I now have black treeview.
