XnView exif location reading error
PSHRutPark
Post by PSHRutPark »
In at least the current release version and the beta I have discovered that XnView is intermittently reading location data (latitude or longitude) in the EXIF incorrectly.
It seems to occassionally change the seconds value and makes it negative. As a consequence the displayed location on Google Maps is incorrect. Other programmes such as GeoSetter (using exiftools) read the coordinates correctly.
The error seems to occur on some files re-saved (post geo tagging) with Capture Nx.
Has anyone else experienced this.
Have sent email with example images.
Thanks
PETER
Re: XnView exif location reading error
PSHRutPark wrote: Have sent email with example images.
Ok, i'll check
