summary: selection rectangle improvements
herr_k.
Post by herr_k. »
darkening outside of selection area
selection snapping to border/other color
selection rectangle scrolls picture when outside of screen
copy/paste not stretched in rectangle when pasting
and i also would like to have a manual choosing of the selection size like "make selection 1680x1050" or "make selction custom size" where i can freely enter the x/y pixels like 200x150 ..
thanks for listening :wink:
Warm water…
:arrow: herr_k
:) Hello !
…and i also would like to have a manual choosing of the selection size like "make selection 1680x1050" or
"make selection custom size" where i can freely enter the x/y pixels like 200x150 ..
• It's already possible to set a customized selection and to save it, please give a glance HERE :wink:
• But :
1. That's not obvious…
2. A dialogue allowing to save several custom selections in the INI (or any special text file) should be better, no doubt.
:mrgreen: VG
herr_k.
Post by herr_k. »
thanks for pointing that out.
it does not work here 1.92.1.
i select 1680x1050 :arrow: save selection as custom.
open another picture :arrow: saved selection :arrow: the selection is always completely different?
then i read about both is saved ratio & size! confusing.
but after setting ratio to FREE and saving 1680x1050 it again does not work! ... :|
and i would prefer to have a field to enter the values manually,
like in the resize dialog.
and also the menu doesnt show the size of the saved selection?..
another suggestion/fix that drives me crazy,
when selecting e.g. 1680x1050 in a big picture i almost NEVER get the 1050, never. always like 1049 and 1051 but never the round count (for this i have to zoom 3 times always,then it works..).
can you please fix this at all full numbers. thx
marsh
Post by marsh »
herr_k. wrote:thanks for pointing that out.
It has a more limited purpose (print size) than anyone might expect when seeing it in menu.
More in old topic: Replacement for 'Set Selection Size'...
