1. Show the number of tagged files in status bar (e.g. "4 object(s) from 2 folder(s) tagged")
2. Change the name of item "Tag" (in Categories) to "Tagged files (X)" (e.g. "Tagged files (4 in 2 folder(s)")
Request: Number of tagged files
Dreamer
Dreamer
Re: Request: Number of tagged files
Makes sense. E.g. the user may intend to choose 100 files out of his/her collection, then it would be useful if the number of tagged files would be shown. (Should probably say "4 file(s) in 2 folder(s) tagged")Dreamer wrote:1. Show the number of tagged files in status bar (e.g. "4 object(s) from 2 folder(s) tagged")
Not sure with the naming. Currently there's "Category", "Rating", "Colour label", and "Tag". "Tagged files" would not really fit to the other labels. But "Tag" does not sound very clear to me, either. Other suggestions?Dreamer wrote:2. Change the name of item "Tag" (in Categories) to "Tagged files (X)" (e.g. "Tagged files (4 in 2 folder(s)")
Dreamer
- Forum Librarian
- Show the number of tagged files in status bar + Show tagged files = Very intuitive
Dreamer
Currently we have 'x object(s) [...]' or 'x object(s) / 1 file(s) selected [...]'Dreamer wrote:1. Show the number of tagged files in status bar (e.g. "4 object(s) from 2 folder(s) tagged")
Do you want to add 'x object(s) tagged' to this status, or replace it?
Dreamer
Add would be better IMHO.xnview wrote:Do you want to add 'x object(s) tagged' to this status, or replace it?
Dreamer
