Hi Experts
Kindly advice me how to open LBP format file which my french business card program labelprint saved my finished card page.
It is well saved, but now my PC tells that it is not able to read and open. Are there any settings in XnView to make opening possinle.
Thanks in advance.
Jusa
Opening LBP format
Not supported
• As far as I see, that *.LBP format is totally absent from the list of supported formats
• You can get it from the Info Menu >> Supported formats, or better classified directly HERE ONLINE
• I think that Pierre'ld need a sample, assuming that this format isn't a “closed¦proprietary” one…
Re: Opening LBP format
Please sned me a sampleJusa wrote:Hi Experts
Thanks in advance.
Jusa
Jusa
Opening LBP format file
Thanks for good and informative reply.. So far I have not found any trick how to open the LBP format saved file. In my PC there exists the LBP format in the file list, but obviously none of my programs do not support that. Just only when I tried to open with Word, it opened but pages were full of "computer text"!!!!
Not easy for a novice like me. The program in which I created the cards is french "LabelPrint"
Regards Jusa
Regards Jusa
Last try---
• Before to send a sample to Pierre as he wishes, I would propose you a last try :
- Go to Options (F12) Under Browser >> File list >> [Misc.] tab, make you sure that the box
“Recognize only by extension” is unticked.
- Then, drag & drop your file from Explorer or another file manager onto the main “View” window.
- Whether it works, that means that the format is usual, but that only the extension is different.
- If it doesn't, you have to send a sample attached to an email (zipped if needed) to :
webmasterATxnviewDOTcom
Jusa
Opening LBP format
Hi Claude
Many thanks for your efforts in helping me. Now things are becoming a bit too complicated to my novice skills and perhaps I"ll leave thi "sudoku" unsolved.
I only wonder how some companies can publish programs with so difficult formats.
By the way, this is very nice business card (and other labels) french origin program LabelPrintPC by www.labelprint.fr and it works well. Now the only obstacle is the fact that I must print my creation as soon as it is finished . No more possibility in saving!!!!
Thanks anyway for your excellet try to help.
Jusa
Jusa
