XnView crashes when using mouse buttons
protobion
Still doesnt work
Post by protobion »
Every version of Xnview since the 1.66 has simply crashed when I use my mouse button to go to the Next/Previous file. No error, nothing. Just hangs.
I am on a Win2k SP4.
I thought I read Fixed : Next/Previous
but it still crashed. Whats up with that?
protobion
Still doesnt work
Post by protobion »
Every version of Xnview since the 1.66 has simply crashed when I use my mouse wheel to go to the Next/Previous file. No error, nothing. Just hangs.
Re: Still doesnt work
protobion wrote:Every version of Xnview since the 1.66 has simply crashed when I use my mouse wheel to go to the Next/Previous file. No error, nothing. Just hangs.
I have no crash. Do you have "Read ahead" or "cache behind" in options/View? Your files are in which formats?
Dreamer
Post by Dreamer »
Very strange, try backup xnview.ini file and delete it, also you could try change option use mouse navigation in fullscreen (if you turn it off, mouse wheel will work, just buttons not, you'll get RMB menu and it may solve your problem maybe...)
