Space key inverts tagging
Currently, when selecting several files which are partly tagged and partly untagged, pressing the Space bar will invert the selection.
From my point of view it should not invert but set and unset the tags of all files.
Dreamer
Post by Dreamer »
I'm not sure, Space should work as "invert", check the menu - view - tag (Ctrl+T, Space, Insert are the same).
Dreamer
