Memory leak when using the double-click feature
Olivier_G
Post by Olivier_G »
I have just noticed that memory of images (current, and eventually of ahead/previous cache) is not released when going back from 'View' (normal or full screen) to browsing with the double-click feature.
A :bug: ?
Added: To be precise, it is never released (aka: a leak), even when viewing other images...
Olivier
PS: I use XnView 1.74 on Windows XP+SP2
Re: Memory leak when using the double-click feature
Olivier_G wrote:I have just noticed that memory of images (current, and eventually of ahead/previous cache) is not released when going back from 'View' (normal or full screen) to browsing with the double-click feature.
A :bug: ?
It's normal, because view is not closed. You can take a look at the menu "Window".
xnview wrote:It's normal, because view is not closed. You can take a look at the menu "Window".
Think like Olivier and other people I find this behaviour surprising. :o I expected the current image to be closed when double-clicking on it.
Sure enough the option in Options > View " says "Double-click to open Browser", not "Double-click to close view", so the current behaviour is correct, but I wonder whether this is really useful and what people need and expect.
So what is better. When "Only one view" + "double click to open ..." must close all view before to return to the browser?
xnview wrote:...
I would expect that the current view (the one you double-click onto) is closed and the browser is opened. All the other views should not be affected.
Olivier_G
Post by Olivier_G »
Doh! :shock:
Right! I didn't even think about it due to the "Only one view" feature...
helmut wrote:
xnview wrote:So what is better. When "Only one view" + "double click to open ..." must close all view before to return to the browser?
This one looks like a winner... :D
Olivier
Dreamer
Post by Dreamer »
Another vote for that.
Also "Only one view" + "double click to open ..." options shoud be turned on by default, because (probably) most users expect it...
