B2 - strange random crashes / error dialogs...
Dreamer
Post by Dreamer »
1. Can't reproduce the first one, this dialog has shown while loading the files, I have changed to other program (using Alt+Tab), then, after about 10 seconds this error dialog has shown:
http://www.mediafire.com/?2q2lczw9p1y
2. Another one, I can reproduce it now, I just open the png image, screenshot created with xnview and press ctrl, or shift. When I press OK, it works good, then. Perhaps it's not a bug, but it's strange, can anyone reproduce it?
http://www.mediafire.com/?ucuympcljxh
Beta 2, Windows XP SP2.
Dreamer
Re: B2 - strange random crashes / error dialogs...
Dreamer wrote:2. Another one, I can reproduce it now, I just open the png image, screenshot created with xnview and press ctrl, or shift. When I press OK, it works good, then. Perhaps it's not a bug, but it's strange, can anyone reproduce it?
ckit ([url=http://newsgroup.xnview.com/viewtopic.php?p=58985#58985]XnView 1.93 beta (1)[/url]) wrote:XnView users!
Remove "pocket.xnp" to avoid the RAPI.dll virus that Pierre keeps creating!
and yes I fell for it again with beta 1 :(
ckit
Post by ckit »
The plugin wasn't included with beta 2, I checked.
RAPI message is from xpocket plugin
Dreamer
Post by Dreamer »
2. So is it a bug? If not, I don't think it's normal, it should be working good, also without removing any files in the final version - it might be considered as bug by most users.
Dreamer
Dreamer wrote:2. So is it a bug? If not, I don't think it's normal, it should be working good, also without removing any files in the final version - it might be considered as bug by most users.
I can't reproduce it
Dreamer
Post by Dreamer »
1. Another crash, the same, standard crash dialog, after adding few favourites and moved few items.
2. Strange, I have deleted all files from xnview folder, re-copied the files from XnView-beta2.zip and I can't reproduce it now.
Dreamer
I had some crashes when using multi-level undo. But not reproducables ones. :-|
