B3 - Tab switching dosen't work good with Fav. and Categ.
Dreamer
Post by Dreamer »
It's working good when I'm using "Folder" in the Tree pane:
- browser > tree pane (folders) > addres bar > browser...
...but when I switch to Favourites or Categories, focus is lost when it soulf be in tree pane:
- browser > tree pane (focus is hidden*) > addres bar > browser**...
* - so it looks it's working (when using arrows and Enter), but it invisible - bug #1 :bug:
** - it's active, but invisible, I have to use arrow, each time I switch the folder in tree pane, also with "Folders", when I just switch between all panes, focus is visible in Browser (just pressing Tab, Tab, Tab, Tab...) - bug #2?? :bug:
Beta 3 - test version, probably also with previous versions, Windows XP SP2.
Dreamer
Re: B3 - Tab switching dosen't work good with Fav. and Categ
right!
Dreamer
Post by Dreamer »
Also for #2?
Dreamer
Dreamer
Post by Dreamer »
Fixed in the final version, thanks Pierre.
Closed.
Dreamer
