Rename doesn't work if other file is tagged
Dreamer
Post by Dreamer »
I'm not sure if this is a bug, or normal behavior.
- tag file A
- go to file B
- press F2 to rename file B
= the name in dialog is "A"
Beta 3 - test version, probably also with previous versions, Windows XP SP2.
Dreamer
Re: B3 - Rename doesn't work if other file is tagged
Dreamer wrote:I'm not sure if this is a bug, or normal behavior.
- tag file A
- go to file B
No it's the normal behaviour, but i think that it's not good!
There is a dialog box that ask if tagged files must be used. It's the same for copy/move to...
But i'm not sure that this behaviour is good and easy to understand if you have selected some files and tagged some files!!!
But i don't know how to do it in a better way
Dreamer
Post by Dreamer »
If more files are tagged, Batch rename dialog is shown, it's OK IMO, but if only one file is tagged - and I click YES in that dialog, perhaps rename should be disabled, if possible, it's a bit confusing now, don't know, it's a minor issue...
Dreamer
marsh
Post by marsh »
This seems addressed in v.1.93.1. As far as I can tell, you must enter tag view/category for F2 to rename the tagged files.
