Another small bug:
In a .tiff file with transparent areas, the selection frame is only shown in areas which are not transparent. So it is hard to find the boxes to resize the frame, or even impossible...
Happens in 1.91.6, 1.92, 1.93b2...
I can send a screenshot, if needed!
regards,
Stefan
no selection frame in transparent areas of .tiff files s
surfacecleanerz
Re: B2: no selection frame in transparent areas of .tiff fil
A screenshot would be helpful. You can upload it using ImageShack for example.surfacecleanerz wrote:... I can send a screenshot, if needed!
surfacecleanerz
Same issue…
• Prior, please avoid German, that forum is in English only (and I can't read much more than that you wrote
• According to your image, it seems that you are using a dark grey background as RGB 128¦128¦128.
Are you ?
• If so, you land in the same issue discussed in your thread HERE (above, below and further…).
• I made a 32 BPP TIF with some transparent parts, I see the selection alright
because I've a pastel-blue background as RGB 198¦180¦255.
- Using the chequered pattern to represent the transparency, you might be able to see the selection OK, like I can do here.
- That's is valid for all formats supporting the transparency,
IMO it's not format-related, it's only a known lacuna in the current selection style…
As Clo has pointed out, already, the problem is the grey background. On grey image parts selection becomes invisible and cannot be seen. Please find a discussion and suggestions in topic Possibility to change color of selection resize fields.
(Thank you for translating your post to English.)
surfacecleanerz
Keep INI
• Since I keep my INI along the versions for ages, I can't say what's the default BG “with an image”…
- That awful grey is there (from Windows) at start up with an empty “View” window only, and also
(as unexpected) in some box where it makes that all is unreadable (the Bill's places : My…blah bla, etc).
• You may change the BG “with an image”, then keep you INI…
- I guess that many users would dislike my pastel-blue, so I don't propose it as new default !
