Quicktime Movies are far too loud ...
boris69
Post by boris69 »
i have a problem with my quicktime movies (.mov).
the volume control doesn´t take any effect.
all of my .mov clips are always at 100% loudness.
xnview can´t control the volume.
is there a solution for this problem?
thank you
boris69
Re: Quicktime Movies are far too loud ...
boris69 wrote:Hi,
Do you have a sample? Do you use quicktime codec?
boris69
Post by boris69 »
It happens with each and every Quicktime .mov-file.
I use Quicktime Alternative 2.40
All other filetypes work fine.
I updated quicktime alternative and xnview - the problem still exists.
