I'd love to see the ability to hide the File, Edit, View, etc menu bar while in view mode. I know it hides in full screen but then I can't see the windows task bar. Hiding the other toolbars are easy, the menu toolbar would be a great addition to hiding.
Everything related to viewing is available in the right click menu anyway.
Hide menu in Viewer
tannim
- Yahoo Messenger: tannimdragons
- Forum Librarian
helmut ([url=http://newsgroup.xnview.com/viewtopic.php?p=30032#30032]Problem with big image[/url]) wrote:In menu "View" you can hide toolbar, statusbar, but not the menubar. But you have fullscreen mode which will hide everything. Select "View > Fullscreen or simply press 'F' to enter fullscreen mode.djsolidsnake86 wrote:another thing: is possible to hide the menu bar (file-modify-visualize-image.. etc) ?
XnTriq ([url=http://newsgroup.xnview.com/viewtopic.php?p=48569#48569]Viewer: Bunch of suggestions (mostly GUI: menu bar)[/url]) wrote:nim wrote:Also I think it's a vital option to be able to disable the menubar.
tannim
Not sure what I am supposed to do with those. One is somewhat related to what I said, the rest are not. I looked before I posted but thre are so many threads and that one was named so badly I missed it.
Full screen already hides the menu bar, I know and spoke of that. I mean for non full screen viewer mode.
