B3: Clear tags after any operation.
marsh
Pressing <alt +c> outside the tag category will clear the tag category. In other words, any non-tagged operation will clear the list of tags. I think only operations which are launched from category view should clear list. Even if that were the case, would it be better to only clear the highlighted files in tag category which have been involved in an operation (copy, move, etc.) leaving the others to remain in list? Ex. Copying 1,2,3 would only clear 1,2,3 but not 4,5 also.
Re: B3: Clear tags after any operation.
Don't know what is better.marsh wrote:Pressing <alt +c> outside the tag category will clear the tag category. In other words, any non-tagged operation will clear the list of tags. I think only operations which are launched from category view should clear list. Even if that were the case, would it be better to only clear the highlighted files in tag category which have been involved in an operation (copy, move, etc.) leaving the others to remain in list? Ex. Copying 1,2,3 would only clear 1,2,3 but not 4,5 also.
Perhaps if the tagged files was not used in the operation, they must not be cleared. What do you think?
marsh
That would be good.xnview wrote:Don't know what is better.marsh wrote:Pressing <alt +c> outside the tag category will clear the tag category. In other words, any non-tagged operation will clear the list of tags. I think only operations which are launched from category view should clear list. Even if that were the case, would it be better to only clear the highlighted files in tag category which have been involved in an operation (copy, move, etc.) leaving the others to remain in list? Ex. Copying 1,2,3 would only clear 1,2,3 but not 4,5 also.
