Wmp Plugin bug
BlueDrop
Wmp Plugin bug
Post by BlueDrop »
Hello to all,
I want to refer a bug that has "wmp" plugin.
When I try to open a folder with this type of images, xnview open the folder but, after processing for some seconds (4-5s) it crash!
This happen only with wmp plugin: is there a solution?
Thanks. Regards.
Re: Wmp Plugin bug
DarkBDBB wrote:Hello to all,
Thanks. Good-Bye.
Could you send some samples?
BlueDrop
Post by BlueDrop »
Instead, can you post some wmp standard images?
As images, I only convert jpg image to wmp image through xnview...
And, do you know that in properties of files, is not displayed the compression ratio?
Bye.
BlueDrop
Post by BlueDrop »
ckit
Post by ckit »
XnView 1.93 beta 3 crashes when I try to open the Properties for this file.
Works, but---
:arrow: ckit
:) Hello !
• It works here, no crash when I ask for «Properties» (local menu), but :
1. It must be displayed as 1:1 scale, or else there is a “grid” of coloured artifacts i.e. as reduced to fit the window.
2. I use old DLLs- There is almost no plugin DLL in the ZIP pack of 1.93-ß3.
- Here : <Xwmp.dll> 304 KiB - July-12-2006
:mrgreen: KR
ckit
Post by ckit »
ckit wrote:XnView 1.93 beta 3 crashes when I try to open the Properties for this file.
This is NOT an OS type bug, I can reproduce it on both Win2000 Pro SP4 and WinXP Pro SP2.
No crash still
:arrow: ckit
:) Hello !
• Here XP-Pro SP1
- I started the file in the browser, asked for Properties from the tab : OK.
- In "View", like said above, OK.
- However : That's a strange image ! It can be viewed properly only when it's shown at a round part of the size,
let's say : 1:1, ½, ¼… as well in View as in the preview. The colours are different according to the scale !
- Of course, the thumb nail (that isn't in a round fraction) is reduced as a pulp of culours…
… but no crash !
:mrgreen: KR
Ok, i have the crash with property dialog, but not by viewing or browsing it
BlueDrop
Post by BlueDrop »
When I speak about "properties", I mean the tab near "preview".
In version before I could see also "quality" of image, but not with this version.
I don't know why crash, but it continue to happen...
The crash arrive when I view a folder with inside a "wmp" file.
I tried to remove the plugin from xnview, and it does not happen...
Bye.
P.S. I'm italian, so is difficult for me to describe the error...
P.P.S. Here the archive with image and error text.
BlueDrop
Post by BlueDrop »
Found the bug!!!!!!!
If you select "View" -> "View as" -> "Icons" the bug can be reproduced!
If you select "Thumbnails", xnview does not crash!
Fix it!
Bye.
P.S. I'm the only one who discovered this bug...Hmmm...
ckit
Post by ckit »
Fixed in XnView 1.93 final.
BlueDrop
Post by BlueDrop »
Have you fixed the bug I referred?
Bye.
