I use the following script.txt (and v4.90 release):
Q:\img\SLIDE-SHOW\menu copy.tif
And in result i see only two files im_01.bmp, im_03.bmp with the identical content... May be I not quite properly understand -n conception? Simply I want to get the next conversion-renaming in result:
How I can use the -n key in this case ?
Some complexities with -n key...
Cinemaizer
DOS386
minor problem
I guess that "-n" is __old__ and was designed to apply to both source and destination file sets, now you use a list from a script (new !!!) to set the source set, so the numbering feature gets confused.May be I not quite properly understand -n conception?
