'Keep document size' in Resize dialog
Warlock
Post by Warlock »
Hello Pierre! :-)
In my opinion one thing would be very very important for a picture viewer in common, respectively XnView.
In the Image -> Resize window, you can "Keep ratio", but you can not "Keep document size" like in the "Set DPI"-action inside "Batch Processing". Photoshop for example has the ideal image resize dialogue. There's the double or triple bracket to keep ratio and/or document size, so you have full control over picture size in co-operation with DPI. It's often very important to automatically have the DPI adjusted when changing the image size.
If you would install a "Keep document size" controll box inside the resize dialogue it would be as perfect as in Photoshop.
I tested many picture viewers and no one has such a resize image dialogue. XnView here on more time has the chance to set apart from other picture viewers (Ok, I know, XnView already sets apart from the most picture viewers!).
By the way:
Once I tested a picture viewer which had one nice and useful thing:
It warned the user about low resolutions. When the resolution was under 200 DPI the DPI number color changed from black to green, and under 100 DPI the color changed to red. That's very nice for the mass of idiot - pardon - beginner users, who don't know much about computer programs
and only want to simply manage and handle their digital camera pictures. If the user could even customize and set those DPI warning limits in the preferences, it would have been perfect!
With kind regards
Thomas
oops66
Re: "Keep document size" controll box in the "
Post by oops66 »
Warlock wrote:Hello Pierre! :-)
By the way:
With kind regards
Thomas
It's a very good idea , and it will be a great improvement !
Yes, it's often very important to automatically have the DPI adjusted when changing the image size (or print size), and it will be a good idea also to have this in the menu : Files\Print \layout tab near the print size too, with these kinds of automatics warnings colors for interactives DPI values :
under 600 DPI value in back - under 300 in green - under 200 in orange - under 100 in red, for exemple
Warlock
Post by Warlock »
Yes, oops66, you're right. That sounds even better. :-D
oops66
Post by oops66 »
Warlock wrote:Yes, oops66, you're right. That sounds even better. :-D
Pierre, what do you think about this ?
'Keep doc size' will be added in 1.93.2
oops66
Post by oops66 »
Great - thanks Pierre
Warlock
Post by Warlock »
Perfect!
It's such a wonderful thing, that users can talk with the programmer and he listens and seriously thinks about suggestions.
That's almost impossible with big software companies.
Thank you very much! :-D
