1.93: Always uses 72 DPI for calculating print size
ilgaspa
I noticed that, regardless of dpi set in the picture, xnview always display 72 dpi in browser "Details" and "Thumbnails + Details" view. It also always uses 72 as the DPI value for calculating print size. Opening the image in the viewer and choosing "print size" from the Image menu displays the correct value of 300 instead
Re: 1.93: Always uses 72 DPI for calculating print size
Could you send me or post a sample?ilgaspa wrote:I noticed that, regardless of dpi set in the picture, xnview always display 72 dpi in browser "Details" and "Thumbnails + Details" view. It also always uses 72 as the DPI value for calculating print size. Opening the image in the viewer and choosing "print size" from the Image menu displays the correct value of 300 instead
ilgaspa
I noticed now that in 1.93 the problem seems partly solved: try opening the linked image. The print size is now correctly calculated with a dpi value of 300, but if you switch to "Thumbnails and Details" mode, in the properties column the dpi value shown is 72x72
http://picasaweb.google.com/ilGaspaPhot ... 5062433442
On this picture there is no dpiilgaspa wrote:I noticed now that in 1.93 the problem seems partly solved: try opening the linked image. The print size is now correctly calculated with a dpi value of 300, but if you switch to "Thumbnails and Details" mode, in the properties column the dpi value shown is 72x72
ilgaspa
Are you sure you downloaded the original picture (there's a link on the right side of the page, something like "Download Photo") and not the reduced version? If you right click the picture and choose "Save picture as" you'll download the dynamically resized version, wich has no metadata. You must click on "Download photo" link on the right hand side of the page... sorry, I should have told that in my previous post
If you prefer I can send it to you via email, just tell me the address
I don't see 'download photo'ilgaspa wrote:Are you sure you downloaded the original picture (there's a link on the right side of the page, something like "Download Photo") and not the reduced version? If you right click the picture and choose "Save picture as" you'll download the dynamically resized version, wich has no metadata. You must click on "Download photo" link on the right hand side of the page... sorry, I should have told that in my previous postIf you prefer I can send it to you via email, just tell me the address
ilgaspa
- Forum Librarian
I have not received it, yes please send me it again
The link doesn't work...XnTriq wrote:Direct link: 070411_083226.jpg
ilgaspa
marsh
Topic is changelog, so there might be something for you to look at.ilgaspa wrote: Hope this helps
xnview wrote: * DPI - http://newsgroup.xnview.com/viewtopic.php?t=14647
