This image: clock-opt.png shows correctly in XnView, but when I try to view individual frames (using "Next page"/"Previous page" buttons), it doesn't display the whole frames.
Also, when I view individual frames I can toggle "Use alpha channel" (Ctrl-H) and "Show Mask" (M), but when I view the animation itself, the options are grayed out and I can't use them.
more APNG stuff
Re: more APNG stuff
Next/Previous page show you the frame stored, and not the frame from animation (like gif)
guest2008
guest2008
Re: more APNG stuff
Unfortunately, the second issue is not fixed in 1.93.2 :
guest2008 wrote:Also, when I view individual frames I can toggle "Use alpha channel" (Ctrl-H) and "Show Mask" (M), but when I view the animation itself, the options are grayed out and I can't use them.
